cad_3326
So, I already have my components and I was wondering if I can cut an mdf ring that will place my speakers in the factory mounts. I mean, I'm almost certain that I can get the speaker to fit the opening, but I'm scared that the depth between the door panel itself (the outside panel under the plastic cover) and the cover for the door panel may be too small to allow me to mount like that. If so, I have two real options, I can cut the plastic covers and glue in a piece that will allow for the depth I need (but I'm scared that I won't be able to get this to look clean). Or OF COURSE I can cut the outer door panel (the metal) and mount my speakers away from the factory location, but I'm thinking that even if I do it this way I'm going to run into the first problem, cause I'm gonna need a mounting bracket of some kind. The problem will be worse for the rear speakers, cause my RE xxx 6.5s are much deeper than normal speakers, so I need a way to tackle the problem intelligently or I'm going to fuk something up (or make it look retarded take your pick)! I don't want to do kick panels because I want to keep the car looking as factory as possible (people don't break into factoy taurus's to steal anything.) Do I have any other options for mounting my speakers and what would you do?
