Xenozx
JVC BT1 head unit
Power acoustik 2000w peak 1200w RMS 1 ohm amp
12 inch Mofo - X 2 ohm x 2 ohm DVC subwoofer
Sub box ported - Dimensions (W x H x D): 19.25" x 14.25" x 16.25" tuned @ 38hz
4 Gauge amp kit - no cap
thin RCA L+R cables
I have a few questions of you guys dont mind answering. I have been on a quest for awesome sound in my car, and have been having trouble getting where i want. I have heard some systems that are exactly what I want. Unfortunately, I have been unable to get the exact sound.
1.) is there a difference in sound quality/SQL when comparing a Competition amp against a regular amp? Same power levels, same settings, can you get a different sound from the 2 amps, or is that something that the sub is solely responsible for?
2.) can cheap/thin RCA cables cause your sound not to be as great or should that not matter?
3.) a Cap, can a cap make your sound better, as I have heard it helps provide stable power to the amp, which can help the sound of the base when its hitting hard, or is that just a myth?
4.) LPF on amp - Where should this be set. I have heard anywhere from 80-120 what is the best, if the sub is going to be doing all the base work, as the speakers in the car are strait up vocal only?
5.) how can you test to see what kind of wattage your amp is really running at, to make sure your wiring is correct? Like how can I be sure I am getting my 1200w rms, and not actually running 4 ohm @ say 400w instead?
I think that is the majority of the questions I have, sorry for being a noob and asking such simple questions.
thin RCA L+R cables
