My Pioneers Sound Distortion
ken2516
Hi Guys I Have A Pioneer Avh4000dvd And Four 6x8 Ts Threeway Pioneers Power By A 900 Watt Four Channel Crunch Amp No Matter What I Do Its Sound Go Low But Half Way Its Get Worst,is It My Speakers Or Amp Or Settings.im Running Full Pass Not To Cear It Up A Little
Door speakers can only go so low, especially cheaper ones. You can have more volume/gain with at least standard high pass setting or less volume/gain with lower high pass. When you try for both they probably bottom out when the volume gets too high. Start at 80 or 100 HZ high pass and see how it sounds. If you don't have a sub and want a bit more bass I'd probably tweek as low as 60 HZ or so but back off on the gain a bit from your optimal setting if you do.
ken2516
ken2516
albany ga
99grandprixGT
