my oil smells a little like gas.
well gas enters from the heads, and oil is below lubing the crank and shit.....so if the rings are leaking, your either A) get oil in the combustion chamber, or B) get gas in the oil. or maybe a little of both if your really lucky lol. either way, its not good. happened to my truck.
well the shop says the grinding noise was the AC compressor. $650 to fix. No word yet on why the oil has that smell. I'm moving it to synthetic next change though.
perfectly normal for there to be a faint gasoline smell in the oil, your rings are loose when you 1st start the car anyways, they're designed to be able to expand when they get hot, so it's perfectly normal to have some blowby when you first start the car, which is why you're NEVER supposed to really get on the throttle until the car's up to NOT, or you risk low oil pressure conditions, as well as scratching the sidewalls, and creating piston slap
and i've scored a/c compressors for under $50 from junkyards
a/c's for *******, anyways, just rerout your belts
That isnt a bad price actually.
The compressors new arent cheap and you will also have to get a dryer + and fluids and hoses that might need to be replaced.
The A/C on the Youkon was $1100 a few months ago. Remember labor is $95 an hour too //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Do as the other guy said...re-route the belt and deal with the wife complaining about the lack of A/C...its winter...she will never know //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
djman37
SOLID
djman37
DFW, TX
Johnny Drama
