My new multimeter reads 0's on every single setting. What do?
justafifteen
And that's the truth.
I got a new multimeter today. It's just the one from walmart, and E-Tek. I have heard good things about them and I thought I'd just give it a shot
So after I bought it, I tried it on my friend's battery and it worked great. I tried it on mine when I got home, and it worked great again. Now that I'm trying to test the voltage on my amp, it just reads 0's on every setting. I can't even get it to read my battery voltage. Just all 0's.
I've made sure it's in AC mode. I've opened it up and made sure the fuse isn't blown. I've had the two wires connected to my battery and have tried each setting around the wheel, and nothing gives. Does anyone have any ideas?
Switch to ohm and touch the two leads together, it should read zero. If it reads nothing or infinity then it's defective.
Oh and to measure battery voltage you need to be in DC and not AC.
It took about a minute to go down, but it ended up reading 0's after going down from .08 very slowly
turn it to continuity, and see if it beeps. Something internal is messed up then, i had that happen to 3 of mine. I always just go back and buy a new one and put my old one in the package and return it.
I put it on continuity and without touching the leads on anything, there's a constant beep
with the leads or with speaker wire? if it did it with the leads turn it to dc and go stick it on your battery
With the leads. I'll try it on my battery in a minute
justafifteen
justafifteen
Ash Tree Lane
justafifteen
