my last ampli,and i can't change it anymore
renier
Vivo BOoOM .i.(0_o).i.
HTG2600D 2000W mono block digital mosfet
SPECS
1x400W RMS at 4 OHMS 1x800W Max at 2 OHMS
1x2000W at 1.3 OHMS
Mono Block Subwoofer Amplifier
1 Ohm Stable
MOSFET Power Supply
PWM(Pulse-Width-Modulated) System
Glass Epoxy PCB With SMD Technology
Gold plated RCA Inputs
Custom Terminal Block for Speaker Connections
Thermal, Overload & Short Protection
Variable Subsonic Filter(15Hz~40Hz,24dB/Octave)
Phase Control 0-180 degree
Input Impedance:10K Ohms
Soft Turn On/Off
Heavy Duty Power Coated Heatsink
THD: 0.1%
S/N RATIO: 90dB
Input Sensitivity: 200mv~8V
Freq. Response: 10Hz~150KHz
Remote Bass Control
Dimensions: 9.82''(W) x 2.34''(H) x 15.16''(L)
i replaced the pyle of shit i had..did i made the right choice?
can this drive my L7S15 dual 4 @2ohms "stable"?
i'm going to add up another battery tomorrow morning..
the cap always weaken below 11.6V when the sub moves..
they told me to add up another batt,so it will going to be stable at 13.4-13.6v..
i hope..
now,i have the chance to hear the real potential of this sub?
how many weeks for break in my sub?
for those who knows better,pls help again..i'll w8
yeah,a lanzar heritage..i didn,t have enough money for an opti..guys here told me that optis are good..and i saw a product review bout it..
what can you say?
it is bad?
the first heritage amp cost me 320..i have only one dealer here at my place..and the peso value against u.s dollar is very low..
sorry,i'm new to sound systems..how can i go off th rms?
I meant like your L7 is rated at 600WRMS (if its the newest model). So I posted those three links to amps that do ~600WRMS @ 2ohms.
What do you mean increase your vehicles current? Like an HO alt or what? All you need is for your electrical to be sitting around 14.4V and you are good to go.
how can i gain 14.4V?if i'm going to do this,it will affect all my electricals on the vehicle?(headlights,etc..)
thanx for helping bro..
no,it's a 15" L7 04'?05'? model..
What car do you have? or do you happen to know what size of alternator you have?
Your electrical should be around 14.1-14.4V already. But once you add an amp, that can change because of the current draw of the amp.
renier
renier
philippines
truckramrod
