my help thread
Jep772
ok i had my 4x6's @ 8 ohms bridged on a 2 channel, everything worked just fine.. i just wired some 6x9's @ 8 ohms and was gonna run em stereo ( doors left channel, rear speakers right channel ) so when i turn the deck on i get a sound like a radio inbetween stations static and when i go to cut the car off and kill the deck it keeps playing and the sub joins in and stays on even with no key in the car. i had to pull the fuses out of the dist. block to get the noise to stop. wtf could this be? i used the RF diagram just to be safe, (+) from amp to one speaker (-) same channel to other speaker and the jumper from + to - i double checked and its all wired up right.
hmmmmmm weird. are ur wired connected right on the h/u. b/c if the shit stays on then its getting a constant 12v fom somewhere if the keys out and all. i would say check ur h/u wires.
i have a 100a fuse under the hood and one 80a between the battery in the trunk and the amps, plus the fuses on the amp. i dunno how it blew so fast. funny thing was i had already noticed the speaker terms. touching the metal on the car and i pulled the speakers out and sat em on the rear deck. then i turned everything back on and it smoked. **** it thats only the 2nd time ive blown something with this system, i aint doin too bad. good thing i bought authorized
Jep772
Jep772
Indianapolis, IN.
Jep772
