BassBEAST88
06' T.H.S
- Thread Starter
- #31
Why cant i just hook it up like i reg would and then as i adjust the gain and bass bost and hz then go from there to how it sounds?
n00b is not an attack at your ego. It's a true fact of your limited knowledge in car audio.Like how can you wire i sub down to 4 ohm?
No. You don't want to send 1200 watts to a 500 watt speaker with limited knowledge and experience.You need to wire your sub in parallel for a 1 ohm mono load. Set your amp to put out ~1200w or so with a DMM. So you would need 34.6v comming from the terminals on the amplifier. If the subwoofer sounds odd, like it is distorting, then back the gain off a bit. And remember, use a test tone to set the gain, not music.
Also, leave your bass boost all the way down (off), and set your SSF to around 65-75Hz; just adjust it until it seems to blend in with the rest of the sound equipment.
n00b or newb = A person with limited knowledge in the field of referance.Im not a newb basically i know how to do everything or most of it but i really dont know what i am doing it called like when i run my dual 4 ohm type r to dual 2 ohm i didnt know like that what was called or what it was i jsut know how to do it!! YOU KNOW! //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
newb //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif We can't help you until you admit you need help //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gifHow can i wire my sub from a dual 4 to a 1 ohm mono load? lol
He is right, you can't.newb //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif We can't help you until you admit you need help //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
With your SSF at 69 you can only play tones above that. n00b.No its all good i will play my burps with 69 SSF i already know where my gains gonna be espicially with how much power i will put to it! I didnt know to play bass songs for the gains but i sure will usually just have late night tip to adjust it! LOL
