My custom PSI Konaki 18"... WTTF.. A nice 12" or pair... What do you have???
andrewtexas123
1. Product:
18" Super Konaki Custom PSI sub
2. Specs:
Its an all black, CF Capped, MONSTER 18" subwoofer. It will do very well in ported applications from 4ft up to 8ft with a mild tuning (somewhere between 28 and 35) for daily ground pounding.
It has a very healthy 3.2" p-p of excursion, a fairly low Fs, and will drop low when asked to!
Will withstand roughly 2000-3,000w rms depending on the user and the application.
Brand New Konaki Motor Assembly w/ Blank Magnet Boot
8 Layer D2 ohm Aluminum Flatwound Voice Coil
Dual 9" Linear Spiders
Dual Sewn Leadwire
18" Heavy Duty Cone Assembly
7" Carbon Fiber Dome Dustcap
8ga Direct Connect Wiring
Wrap Around Rubber Gasket
NOW HERE'S THE COOL PART:
The black 18" 6 spoke basket has 1.5" holes milled into it to allow for direct access to the bolts holding the basket to the motor. These bolts can be easily removed with a 10mm wrench (ratchet wrench is MUCH easier), allowing the entire top assembly to be removed and swapped to another motor, or to allow for a different top assembly to be mounted to the motor.
The removal of the basket isn't something that I would call "quick", but it's definitely do-able. I've taken it off and on quite a few times now.
I've tallied up the total cost for this subwoofer, pricing each individual option, and the value of the subwoofer would come out to be right at $500.
The Konaki motor is arguably as good or better than most large sub motors out there now. It has a large enough gap to allow for an 8 layer coil, large 220mm magnets, and tons of cooling vents in the motor. Its just as strong as most, and cools better! It's a VERY proper choice for a high output daily subwoofer like this. I could have used a Nightshade or RE MT motor for this woofer, but the Konaki is a better choice IMO. It took it off a built, but brand new 1207A.
If someone is interested in just the top assembly, I would consider selling it without the motor! The top would work with lots of different motors! It would be just great on RE MT's, Sundown Nightshade, Fi BTL's, etc etc etc... basically anything with a large enough gap, a standard bolt pattern and a top plate within 2mm of 25mm in height!
These are ALL BRAND NEW parts. This is a BRAND NEW subwoofer. It's got tons of add-on's and upgrades above most anything available right now. If you need a badass 18" that will drop LOW, this is it!
T/S Parameters are as follows:
Sd: 1230.00 cm^2
Vas: 126.00 l
Mms: 443.08 g
Rms: 12.52 Ns/m
Fs: 31.0 Hz
Bl: 26.76 N/A
Re: 3.90 ohm
Qms: 6.89
Qes: 0.47
Qts: 0.44
Spl: 90.9db 1w/1m
3. Description/Condition:
Used about 3 weeks and not given more then 1500 watts
4. Price:
$375 shipped
Trade for a kick *** 12"
Feedback:
http://www.caraudioclassifieds.org/forum/itrader.php?u=3212
http://www.rcgroups.com/forums/itrader.php?u=92175
5. Pictures:
your such a tool get a ****in life
cry me a river feggot. you will never sell anything on this site. should have been a man and left my thread alone. not kool whenits done to you is it? with your knockoff dd sub //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
To bad I have sold multiple things on this site already.
didnt evem read the thread.. I understand now why every one on CACO hates this place, they have a solid reason.
right you didnt read the thread but still dumped on me...fvck you caco guys taking up for everyone. seller admitted he messed up. i never bashed him....go back to CACO
Are you kidding me I have never scammed any one on caco go look at all my feedback. Mich had a buyer beware thread because the guy (not me) was busy and didn't ship his item out. I told mich to calm down cause he were posting every day about it.. I told him to wait another week and if he don't get tracking then come back and ***** about it. What do you know two days later he got the tracking.
I WAS NOT even a part of the deal just helping you out.
Mich is just a little butt hurt cause i told him to calm down..
andrewtexas123
andrewtexas123
Danville, Ca
andrewtexas123
