Im not sure what a power wire is but i would suggest just bring your car in and we'll take care of it. We can probably just hook it up to your lighter and run it under the seat. If you have a lighter in the rear, thats a plus.how much will you charge me to run my power wire thru the fender? also i want 4 6x9's laying on the rear deck of my car. how much for that also?
Actually that is my altima. Alot of this was just a joke. I did replace my "custom baffles" with real 6x9 to 6.5 adaptors. The amps dont usually look like that, only when im changing stuff around. The head unit, the a-holes at the shop didnt have the bottom fill piece when they installed it recently and i keep forgetting to go back.thats so retarded.. lol i would of killed u if that was the inside of the altima
Expanding foam is up next, i probably will use some of it to cover up that hole under the head unit too. Thanks for the tip.nismos is happy in his pants at the quality of this install. I'd give it an 8/10. need to put expanding foam behind the head unit to keep out cd skipping demons
can i pay with foodstamps?Im not sure what a power wire is but i would suggest just bring your car in and we'll take care of it. We can probably just hook it up to your lighter and run it under the seat. If you have a lighter in the rear, thats a plus.
Speakers. First off, you dont mount 6x9's on the rear deck. Its much better to put them on the dash right in front of your face unless you have rear passengers all the time. . I have some special glue & tape that can keep the speakers in place without having to deal with screws & such. Since we would be going with the glue or tape, it would save you a hell of alot on the custom baffles. I could probably do it for 100.00 or so unless i had to do the wiring. Then i'd have to charge an extra 75 for all the holes i'd have to drill through your dash board to wire it properly.
Nah, im all set on food stamps for now, but hit me up next month and maybe we can do somethingcan i pay with foodstamps?
