mysilver02alty
Ive had many people amazed by my custom installation skills and tell me i should post my pics so here goes. Sorry, i could only post 10 images. The rest you gotta click the links
Head unit - notice how the rca wires show through the bottom for easy access.
Sub & box
Top of box, custom stained
http://i139.photobucket.com/albums/q313/mysilver02alty/customstainedbox.jpg
Customized amp rack - bling bling!!!
Rear deck & custom speaker baffles so that i could switch from 6x9's to 6.5's. Notice how i drilled the holes upside down. This was for sound quality purposes. Only using 2 of the 4 speaker holes to screw the speaker in was also for SQ purposes.
http://i139.photobucket.com/albums/q313/mysilver02alty/speakerleft.jpg
http://i139.photobucket.com/albums/q313/mysilver02alty/speaker.jpg
http://i139.photobucket.com/albums/q313/mysilver02alty/custombaffle5.jpg
It took me a while to precisely shape the wood to fit, but it came out pretty smooth as you can see in the following pictures.
http://i139.photobucket.com/albums/q313/mysilver02alty/custombaffle1.jpg
http://i139.photobucket.com/albums/q313/mysilver02alty/custombaffle4.jpg
Had to use some more of the foam to restrict movement of the rear deck. used the white foam this time since white foam increases SQ.
http://i139.photobucket.com/albums/q313/mysilver02alty/deckfoamdeadener2.jpg
Deadened trunk lid. Used foam to keep trunk lid from flexing
http://i139.photobucket.com/albums/q313/mysilver02alty/foammaterial.jpg
http://i139.photobucket.com/albums/q313/mysilver02alty/foamontrunklid.jpg
Sound deadened spare tire area as well. Used green sound deadening material instead of the white because green adds SPL.
Custom paint job
http://i139.photobucket.com/albums/q313/mysilver02alty/scratch3.jpg
http://i139.photobucket.com/albums/q313/mysilver02alty/scratch2.jpg
http://i139.photobucket.com/albums/q313/mysilver02alty/splashguard1.jpg
Not everything was smoothe sailing along the way. I happened to break the bulb for the rear deck light.
http://i139.photobucket.com/albums/q313/mysilver02alty/brokenlight.jpg
Im pretty sure it was due to the yellow foam which i was using when i first started customizing. I thought yellow = sq but i found out later it = spl and my light was broken because of this.
If any of you need any custom work done, my prices are pretty reasonable.
Some other pics
http://i139.photobucket.com/albums/q313/mysilver02alty/16.jpg
http://i139.photobucket.com/albums/q313/mysilver02alty/17.jpg
http://i139.photobucket.com/albums/q313/mysilver02alty/15.jpg
http://i139.photobucket.com/albums/q313/mysilver02alty/14.jpg
http://i139.photobucket.com/albums/q313/mysilver02alty/13.jpg
http://i139.photobucket.com/albums/q313/mysilver02alty/12.jpg
http://i139.photobucket.com/albums/q313/mysilver02alty/11.jpg
Sub & box
Custom paint job
Some other pics
