my car wont stop rattling
Daniel
Caraudio.com
863
SFLA
i applied edead all over the place, and the only rattling that it stopped was on the license plate, i tightened everything and it wont stop rattling, i dont know what to do anymore. can some one help me out?
Are you completely sure it's the interior of your car? I mean if it's constant it could be a multitude of things, like your hood, mufflers, catylitic converter, etc. Maybe you should track it down, it could be as slight as a loose wire tapping against the door.
i got a 97 ford contour gl
i dont know how to check all the areas when i can hear is the bass, i turn it down and then the rattling stops, so it has to be somewhat loud when i track it but im not sure where it is coming from, i can hear the general area but i cant pinpoint the spot..
what i did to track down my ratteling, i played a loud track and got under neath the car and checked to see if there was anything moving,ratteling, i fixed most of my problem i found out it was the wheel well, so i filled it with insolation. it fixed most of the ratteling
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
306
A Link would be very helpful. Id be interested in taking a look at some gear
281
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
737
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
Daniel
Caraudio.com
Daniel
SFLA
carguy
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
