**My Brain Hurts** Please stop in and help... ;)
So apparently DeathByBass agrees with Jason...
I need to be 10000000% sure. I'm tired, I've inhaled A LOT of resin, and for some reason it makes me think that the Jason&DBB way doesn't make sense.
So, essentially I'm trying to get people to at least be in agreeance with eachother... before I do it.
nG
it will work
the speaker is just a reactive load, the amplifier doesn't see its polarity at all.
all the phase of teh speaker will determine is which way the cone moves with the peaks and dips in a sinewave.
Yours looks much better than mine, but that is how I would do it.
Once you get it set up, just check each line with a 9v battery before you parallel them all.
We actually just decided to do that... have a 9V in hand... brb...
it will work
Sweet.
Thanks people... my brain is thawing a little now...
nG
Noah couldnt get this figured? Resin fumes in yo' lungs FTL.
hook the whole thing up to a car battery when you are done to make sure they all move the same way to ensure you got the wiring portion of the diagram correct.
I figured it out... pretty quickly... but then I questioned Jason and Myself... //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Wanted to be 1000000% sure... and as stated in this thread... used a 9v battery... and it worked perfect. Also, it DMM'd @1.1ohms DCR.
nG
sweet. Now finish it all and get vids or //content.invisioncic.com/y282845/emoticons/ban.gif.ce8465566702ef9f72e97e794ed1c86a.gif
ngsm13
BSEE
ngsm13
Cincinnati, OH
CBFryman2
