**My Brain Hurts** Please stop in and help... ;)
ngsm13
BSEE
Ok, so currently... my brain hurts... a lot.
I have:
SIX DVC 1ohm woofers. (12 1ohm loads)
I series each woofer. So SIX 2ohm loads.
I series each pair of woofers. So THREE 4ohm loads.
I parallel the remaining loads. So 1.33333ohms final load.
Here is the kicker, 3 woofers are inverted. 3 woofers are not.
How do I wire the 3 inverted woofers out of phase? And still come out with a 1.33333ohm load.
Thanks for playing the game.
nJizm
hold on, thinking
Here's an idea.
Wire the subs into 2 banks. The inverted ones and the non-inverted ones.
Wire the non-inverted ones like you have already, then wire the inverted ones in reverse phase.
Are you running 2 amps?
hold on, thinking
Kthnx.
cant wire them in pairs //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
That's what I was thinking... can't wire a out of phase... with an in phase woofer. Both have to be the same way... //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif...?
nG
i got it figured out for ya ng
parallel the 3 inverted ones t/g ( out of phase by switing the pos and the neg ) 2/3 or.666
parallel the 3 non inverted ones ( in phase) 2/3 or .6666
series those together 4/3 or 1......
Can you series together out of phase and in phase woofers?
Thats what I was going to suggest, but I wasn't sure if you could do that.
yes just be sure to when u are wiring them together wire them backwards.. i think...
Lol...
Confusing wiring ftl.
Thats the problem with that. You have to wire them in "series", but you're connecting the positive of the non-inverted with the positive with the inverted, and the same for the negative.
Hence you can see my confusion.
So apparently DeathByBass agrees with Jason...
I need to be 10000000% sure. I'm tired, I've inhaled A LOT of resin, and for some reason it makes me think that the Jason&DBB way doesn't make sense.
So, essentially I'm trying to get people to at least be in agreeance with eachother... before I do it.
nG
ngsm13
BSEE
ngsm13
Cincinnati, OH
CBFryman2
