my amp will not turn off?
since the remote turn on draw very little current you can tap into almost anything that turns off/on when you tun the key
cig lighter(most of em, test before you do anything)
the radio (red wire)
go to your fuse box
take your remote wire from amp
use a fuse tap
piggy back a fuse that gives 12 volts when key is in the ignition position , and no power when key is removed
use a meter to verify
tn_joeysome
tn_joeysome
Knoxville
350zspl
