my amp keep shutting off on me...help
playboyace35
My amp keeps shutting off on me every time i turned the volume up. Am i not getting enough power to the amp?
here is my setup
Hifonics Brutus amp 1606 - 1600 watts rms @1 ohm, 1100 @2 ohm, 550@ 4ohm.
2 12" Alumapros 500 watts rms each @4ohm
JL Cleansweep
Kicker Amp 4channel ZX.650
a/d/s 346cs 6.5 component speakers
Diamond Audio 6.5 Hi End Coaxial D661i speakers
the power wires from the battery to the distribution block is 4 gauge. Then the distribution block splits the 4 gauge into two 8 gauges. One of the 8 gauges goes into the Sub amp, and the other 8 gauge goes into the speaker amp. Do i not have enough power because of the split?
I would say starving the amp for current is possible.8awg feeding an amp trying to make between 800-1,000w generally isn't the best way of doing things...
so should i just say screw the distribution block and just INDIVIDUALLY wire two 4 gauges to each amp?
Or should i get 2 gauge wires and get a distribution block that goes from 2-4 gauges?
What is the best option for me? IF this is the problem.
its 8 ohms, and the shop wired it so it can be ran at 4 ohms
It can be, but is it? In other words, which of the following configurations are you running?
1600 watts rms @1 ohm, or
1100 @2 ohm, or
550 @ 4ohm
You're also running a Kicker zx650.4?
The Kicker will draw somewhere around 90 amps at full power (14.4v, 650 watts, 50% efficiency).
The Hifonics will draw (14.4v, 90% efficiency):
1600 watts: 123 amps
1100 watts: 85 amps
550 watts: 42 amps
Those amperages are only estimates, based on 50% efficiency for class AB amps, and 90% for class D. We don't know the actual efficiencies of those amps.
If your total amperage is only 132 amps (for the 550 watts configuration), then 4-gauge from the battery to the back will be barely acceptable. If you want to run more power (by upgrading your subs), the 4-gauge is not acceptable.
8-gauge wire is only good for up to about 55 amps, so it isn't acceptable to use 8-gauge after the distro block for either of those amps, since they both draw more than 55 amps.
I think you need a single run of 1/0 from the battery to the back, which will split into two 4-gauge wires to your amps. A good rule of thumb, is look at the fuses on the amps, and size your wire accordingly.
-- Kevin
1100 @2 ohm, or
550 @ 4ohm
1100 watts: 85 amps
550 watts: 42 amps
-- Kevin
Sorry for the confusion, but yeah it is running at 4 ohm. I guess from what your saying is that i should run either an 1 or 2 gauge wire from the battery to my distro block and then split it to two 4-gauges to each of my amp. That should fix things up right?
BTW, you said its unacceptable to use the 8-gauge wires as of now, so that means this setup is the cause of my problem right?
(should i invest in a capacitor?)
playboyace35
playboyace35
oakland, ca
playboyace35
