MX 12" Specs & Pictures
valant_94gt
reSQL
MX Series
12”
Mounting Depth - 10.25”
Mounting Hole Diameter - 11.375”
Overall Diameter - 13”
Bolt Hole Circle - 12.25”
Motor Width - 8.5”
Motor Depth - 2.5”
Basket Depth - 7.75”
Displacement - .19 cu. ft.
Weight - 33 lbs.
MX Series
12”
Electrical Q Value -Qes: 0.503
Mechanical Q Value -Qms: 3.206
Total Speaker Q Value -Qts: 0.434
Free Air Resonance -Fs: 23.165 Hz
Equivalent Compliance -Vas: 59.0 liters
One-Way, Linear Excursion -Xmax: 22 mm
Efficiency - SPL 1W/1m: 83.5 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 1.4 ohm per coil
Nominal Impedance -Znom: Dual 2 ohm
Thermal Power Handling -Pe: 1500 W
Force Factor -Bl: 14.56
valant_94gt
reSQL
valant_94gt
NORWALK ,CA
valant_94gt
