Multiple subs vs single large sub
Ok for one sealed should be out the window....and ur not squeezing 6 10.s or 4 12.s in ur impala trust me ..not in a decent box anyway..what are you.re goals ?? howbeill they be powered? too many variables
2 12 s is the way to go in that car trust me ...back when i went from a dd9515 to 2 dd3512.s was noticably louder on same power
---------- Post added at 12:53 AM ---------- Previous post was at 12:53 AM ----------
Was thinking of running some Sundown Sd subs off my Sundown 2500d
Why sd.s ?
2 12's faced forward sealed from trunk right? I wanted to do that in the first place but I had a BTL 15 from another car. I didn't want to sell it so I put it in my Impala with 3.5 cubes and now I want more
Not necessarily so far my impala has been loudest subs and port back ..didnt like the sound of sealed forward...another option is subs forward port side ...that will be my next box
Yea I was thinking 2 12" FI BL's off my 2500d..do you think they would get as low as a 15 btl?
If you put them in a box thats tuned around the same.
Dont expect your 12s to hit as low in a box tuned to 40 hz if your BTl is tuned to 30 hz
Ok ill just do the two ohm for now .i have really good electrical .ill prolly just go ahead and buy a bass 8 or 12 k for now until i can get a...
To add the tv, I got a second deep cycle battery, ran thick cable from my starter battery to the deep cycle battery(or you can run to a dc to dc...
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
I have a 2012 Ford F150 Platinum Crew Cab. I was saying that since my secondary battery would be grounded to the frame could I not ground my amps...
AndrewHD
AndrewHD
Orange County, CA
AndrewHD
    May 16, 2024
    May 16, 2024
