rzj90059
Can someone post a diagram on how to wire 2 batteries, 1 stock and 1 optima, please, im the visual learner type,lol. Thanks in advance
you don't have to ground it back to the first battery.made this for someone a while ago, but its the same concept
redtops generally aren't used as second batteries. you want to fuse within 18" of each batteryCan i insteed, acording to the diagram do this:
In place of the red top, use my stock bat up front, and in place of the bat cap, use my red top, adn do i need any isolator or fuse in-line
true, i just made it to tailor it to the wants of the other guy.you don't have to ground it back to the first battery.
the redtop will work. it is a dry cell correct? yellowtops have a much better reserve capacity which is benificial as a second batterywell how can i do this cuz i cant really afford another optima right now, i only have the option ofthose two batteries right now
your a progressive thinker. stop that //content.invisioncic.com/y282845/emoticons/hitbybrick.gif.68a672fae224041f00769a97c2c1bf2d.gifgo ahead and use the redtop in the back, then once you save up, put the redto up front and get a yellowtop for the back
yes except i'd loose the cap. also i didn't see any fuses on that power wire. it's very important to fuse at each battery. also you can ground the amps back to the second battery. also if you let you car sit for a few days or run your system with the car off, you may want to look into a relay/solenoidCan i do this![]()
and once i have money throw the red top in the front and put a yellow top in the back
