Trying to figure this all out so I can make sure I got what I need and do it right the first time. Here is what I am trying to wire up.
2 eclipse da7232 amps
max power 2000w x 2
power output 2000w(2 x 1000w) @2ohm 1000w(2 x 500w) @4ohm
2 eclipse 33250 amps
output power 200w x 2 @2ohm 130w x 2 @4ohm 400w x 1 4ohm bridged
I was thinking 3 runs of 0awg wire, then split 1 run down to 2 4awg, running 0awg to the big amps and 4awg to the smaller amps. Is that necessary? Should I add some batteries? How would you recommend getting all those wires hooked up to a battery(s). It is going into a regular cab pickup, so I can put a couple batteries in the bed. How big of an alt do you all recommend?
Just looking for a little advice specific to my application.
max power 2000w x 2
