euroticcustoms
I bought 2 Memphis Power Reference 12's in a slot ported box with a Cerwin Vega Mobile 500.1 amp, used less than 2 months for $250 in Feb. I own a 3000GT with a very small trunk so I couldn't get the box to fit. Anyway, I bought a 1.25 cu. ft. sealed enclosure for 1 subwoofer until the weather got warmer and I had time to build a box.
Originally the subs were wired parallel at 2 ohms. They're single 4ohm voice coil subs. The amplifier boasts 500 watts RMS at 2 ohms, 250 RMS at 4 ohms. Well, when I stepped down to 1 sub, the amplifier's load decreased by half. Anyway, I didn't touch the amp settings, no distortion whatsoever and it hit HARD. A couple months later the subwoofer started cutting out at low volume levels...turn the volume up and the sub would start working again. It kinda sounded like the voice coil was starting to come unwound. Well, finally the sub quit altogether. The speaker felt "semi" tight, so I swapped it out for the other one. The sub still didn't work. Solid green light on the amp with ignition/radio on. No green light with radio/ignition off as normal. I thought maybe the RCA's had shorted onto the amp body as I had them running under the amplifier and the amp screwed down. I disconnected the RCA's, loosened the amp and inspected the wires - they looked good. I had a buddy pull up beside my car and we ran his RCA's to my amp. No go.
I haven't pulled the amp from the car yet to open the case. Was just wondering if this was a common problem with this amplifier? I'm pretty decent at fixing anything electronic, was just looking to see if anybody had run into this problem? I'm not sure if it's on the input or output side of the amplifier. I don't have the high input plug-in or I'd try that route to try to rule out the RCA input as being defective.
All fuses on the amp are good, it turns on, just no output to sub. Anybody?
