Multi Amp Choices
Lunatic07
I need a high amp for my 4 interior speakers and my 4 tweeters. Which one is better?
Clif Designs CD4.4LX
1400 Watt 4 Channel Amplifier
4 x 100 Watts RMS @ 4ohms
4 x 150 Watts RMS @ 2ohms
4 x 175 Watts RMS @ 1ohm
2 x 700 Watts MAX @ 2ohms
2 Ohm Mono Stable
Double-sided Military Grade PCB Board
Regulated Power Supply
Soft Start Circuitry
Full MOSFET Circuitry
4-Way Short Circuit Protection
Variable Frequency LPF 40Hz-120Hz
Variable Frequency HPF 120Hz-800Hz
Variable Bass Boost 0dB to 18dB
Frequency Response: +/- 1dB 10Hz-40kHz
0.02% T.H.D.
S/N Radio > 100dB
Channel Separation 70dB
Silver Plated RCA Input/Output Connectors
Damping Factor 200
4 Gauge Silver Power Connectors
Dimensions: (LWH) 16.5" x 10" x 2.1"
Alphasonik PMZ12005A
75 x 4 + 200 x 1 Watts RMS @ 4 ohms
120 x 4 + 320 x 1 Watts RMS @ 2 ohms
150 x 2 + 320 x 1 Watts RMS @ 4 ohms
Dimensions: (W x H x L) 9 1/4" x 2" x 18 15/16"
Bridgeable
MOSFET High Speed Switching Power Supply
Solid Brass Nickel-plated Terminal Blocks
Milspec Double-Sided Glass Epoxy Circuit Board
Tiffany-Style Input and Output RCA Jacks
Thermal, Short Circuit, Overload and DC Offset protection
Thermal Cooling Fan
Hifonics ZXi 8006
RMS @ 2-Ohms: 4 x 110-Watts + 300-Watts x 1-ch
RMS @ 4-Ohms: 2 x 220-Watts + 200-Watts x 1-ch
RMS @ 4-Ohms: 4 x 55-Watts + 200-Watts x 1-ch
Inputs and Diagnostics:
Variable Input Level Control
Power and Diagnostics LEDs
DC Short Circuit Protection
Over-Load Protection
Connector Types:
Unbalanced Inputs (RCA’s)
Full-Range Line Outputs (RCA’s)
Molded 4-Gauge Power Inputs
Molded 10-Gauge Speaker Outputs
Lunatic07
Lunatic07
Daytona Beach, FL
Lunatic07
BP1Fanatic
BP1Fanatic
