Mulitple Amp use
on most amps there is two sets of rca in puts there should be one for input and one for out put if you wire the amps up then run the rca cnbles from the one amp to the other you should be good to go
it should not be any problem to use a splitter - the input impedance of amplifiers is in the range of 10000-100000 ohms and using a splitter (or halving the input impedance) should not be a problem for the head unit output because it will still be kiloohms and its not hard to design a line level output section to handle that.
karas3434
karas3434
central new york
vasyachkin
NorthFramingham
    Jun 30, 2026
