Much difference between BX1000D and BX1500D
Yea, I dont think the 500 watts would be noticable.
Also, isn't 3dB about twice as loud ot the human ear?
And the BX1500 has been benched by someone on SD and produced somethin like 1378 @ 1ohm so the difference wouldnt even be that huge.
The difference in 500watts and what you would hear would depend on your sub and the box it is in. Some companies have graphs that show how excursion increases as the power increases and this depends on what frequency they are using. For example A balanced sub in the right enclosure in a perfect world with an Xmax of lets say 30mm would work like this:
With a 35hz signal
500 watts would produce 10mm of excursion
1000 watts would produce 20mm of excursion
1500 watts would produce 30mm of excursion
Some subs depending on enclosure will reach xmax at 50% of rms and anything over that is just slamming the suspension.
Overall I would not mess with an upgrade from the 1000 to the 1500, I do not think that there would be that much more output with the additional 500watts since you are are already running around the RMS of the sub. Now if you were only running 500 then I think the additional 500 would definately make a noticable difference. IMO
..... you running a dual 2 ohm L7 I assume??
Well I had 1000w running to my dd3515d and now I have 1700w or more going to it and I notice a huugge difference. I cant have it at near the same volume that I did before. It hits so much harder and louder.
DbRufus1234
DbRufus1234
Northport, Alabama
iamamp3pimp
