MTX modded 1501D
Deusle
what does the phase switch do?
it can either be set to 0 or 180?
i heard you only need it if you have 2 amps together but idk
also its a mono amp but it has 2 speaker output channels
whats the best way to hook up a single sub?
its a D1 sub ran in parallel
the terminal reads .6 when ran this way
The modded 1501D should not have a problem with 0.6 DCR with a good electrical system.
I almost commented on the 0.6 ohms. I assume that is DCR measured with an ohm meter. If it is, that seems a little high for dual 1 ohm coils in parallel. Sounds like either dual 2 ohm coils, or something like an MT that you could get in dual 1 ohm DCR, or added resistance somewhere in the wire/connections.
Brian
i bet if he touched the dmm leads together it gives him a few 1/10th's of an ohm either way... that could be the discrep //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Deusle
Deusle
SD SoCal
jco1385
