MTX LSX2 old school crossover MINT
spltuscon
Kick-*** box builder
833
NH
Mint condition LSX2 old school MTX electronic crossover in plastic wrap, original box, with manual, bass knob and high level input plug.
Almost no use, I bought this new in the late 90's and used it for maybe a week in my car before switching setups and returning it to the box. So it has sat unused for a long time and it's in perfect working condition. These aren't cheap crossovers like most on the market now, this is a nice SQ unit with good build quality.
-Large signal capability-accepts up to 8 volts RMS input signal
-18 db/octave slopes
-EBC- External bass control (bass knob)
-Buffered output stage (only 100ohms at RCA jacks) to drive multiple amps with ease
-Phase reversal switch
-Front and rear RCA inputs (can be used as 2 channel or 4 channel with fader)
-Front high pass output 30-8000hz (there is a 20x multiplier switch)
-Rear high pass output 30-400hz
-Sub low pass output 20-200hz
$85 shipped
Paypal only please and no trades
I don't want to sell the knob separately. That would hurt the chances of this selling...
High level input is for tapping into the speaker leads for signal instead of using RCA's. Usually used when you don't switch the factory head unit out.
Any from that generation will, I had several that worked with it. Not sure on any newer stuff though since I haven't owned any.
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
863
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
There is the 16pin connector in armrest of my old mercedes 2006 S350. Any possible way I can stream music from my phone wirelessly(Bluetooth) or...
spltuscon
spltuscon
NH
spltuscon
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
