MTX Audio or Pioneer?
Hello
Which pair of rear 6x9 speakers would be better for a 2002 accord EX?
Pioneer TS-A6963R
Speaker Size 6" x 9"
Design 3-way
Tweeter Design Dome
Tweeter Composition PEI Titanium
Woofer Composition Carbon Graphite IMPP Interlaced Aramid Fiber
Woofer Surround Butyl Rubber
Peak Power Handling 270 watts
RMS Power Handling 40 watts
Sensitivity 93 dB
Frequency Response 28 - 28,000 Hz
Impedance (Per Voice Coil) 4 ohms
Top-Mount Depth 2-7/8"
Bottom-Mount Depth N/A
Cutout Dimensions N/A
- or -
MTX Audio TDX6903
6" x 9"
Design 2-way
Tweeter Design Dome
Tweeter Composition N/A
Woofer Composition Reinforced Paper
Woofer Surround Rubber
Peak Power Handling 200 watts
RMS Power Handling 100 watts
Sensitivity 92 dB
Frequency Response 42 - 20000 Hz
Top-Mount Depth 3"
Currently installed components:
Alpine CDE-123 head unit
KCE 400BT bluetooth module
Focal Polyglass 165VB in the front doors
Pioneer TS-A6963R
What would be a nice pair of rear 6x9 rear speakers I could install in the future within a $200-$250 range?
Thanks very much for your insight!
*I had links to all components but because I'm new the site blocks me from including them. Let me know if you need them. I went ahead and pasted the specs listed on the Sonic Electronix site.
Thank you, Grimy. I have no plans for beast bass in the trunk so I'd like to maximize the rear speakers.
I drive about 600 miles a week and need the trunk space but just wanted to have decent sound since I drive so much. I mostly listen to drum n bass.
I'll stick with the pioneers for now then.
ok, now I'm not sure which way to go.
If it's more bass I need then I should get the mtx in there and if I plan to get some sort of sub installed I should go with the pioneers right?
Just to clarify I already have both sets of these. The pioneers were in the accord when I got it and I have the MTX from a while back. Not looking to purchase higher end ones yet but I am open to suggestions.
If you're going to get a sub, don't use your rear speakers at all. Where are you getting these speakers from? They're both discontinued models.
Oh, and those MTX speakers are 3-ways as well. The listed specs are wrong.
There will not be a sub. At least not anytime soon. I need my trunk space for work.
The Pioneers came with the accord when I got it. The MTX I bought several years ago and have just been lyin around.
Thanks for pointing out that error.
Due to using HU power u want the speakers that are the most efficient with power and based on the listed specs I would go with the Pio's as they have a Sensitivity rating of 93 dB vs MTX's 92 but this also could be false due to not knowing how they got those numbers each manf uses a different process. Since u own both drop them in and see what sounds best to you.
Id say get you a nice low power amp maybe 200watts or less 4 channels and run it to all you your speakers this will give you added output and you could add the other 6x9 s if you have room .the 6x9s are a full range speaker so depending on the speaker ,the can drop down into the low range and play as a subwoofer and its just fine.when setting the amp just use full range
Perpetrator
Perpetrator
Los Angeles, CA
lilboom
ThxOne
    May 13, 2026
