MTX Audio have big ones
sry but i didn't see any of those 5 times could you give me a readers digest?
Well from a quick search here are some of the quotes;
That comparison is totally meaningless. It really proves nothing. That 10% difference in Xmax (in this case, 2.5mm) is literally inaudible.
Power handling doesn't really matter to overall performance, having 250w greater thermal capacity doesn't make it any better from a performance standpoint. (that's excluding the fact that W7's can handle a bit over their rated RMS power handling aswell)
"Smallest useable" enclosure size //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif I could use a .1cuft enclosure if I really wanted.....hence it's "useable". Extremely ambiguous, and doesn't really make the 9500 any "better" than the W7 even if it were true. And 1cuft for the W7 is still a pretty darn small box....not like you'd need a truck to tote it around.
The rest of it is just general sub-to-sub design difference
I don't really give a darn if you have more Xmax than I do if mine's more linear with less inductance //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
It also just compares the 10W7 and the 10" 9500.
I did the math, and the 12 and 13w7's spank the 12" and 15" 9500s, respectively. You don't see em publishing that, though //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The shortening ring is about the only thing worth noting. I would much rather listen to a w7 over a 9500 any day. I really dislike the sound of the 9500s, 8500s, 7500s, and basically every MTX driver I have listened to and owned.
Would be interesting to see how thick that shorting ring actually is and see if it actually has any effect at low frequencies.
BMW Sidewayz
BMW Sidewayz
Bloomfield, NJ
BMW Sidewayz
