MTX 6500d and DVC sub wiring help..
barfy
Hi all.
I have a MTX 6500D amp and I want to wire in a DVC sub.
I have a Explorer Sport 2dr with a MTX 10" stealthbox in it.
The problem is I dont know how to do this or what type sub I should get,
Should I get a dual 4ohm 10" sub and wire it @ 2ohm,
Or should I get a Dual 2ohm and wire it @ 2ohm.
If I get the Dual 2 ohm, how do I wire it to produce 2ohm for the 6500d.
I am lost here, Can somebody shed some light on this as it is driving me nutzzz!!//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Thanks
P...
Thanks for the heads up .
I took the plunge and ordered a INFINITY KAPPA 10.d 10".
This has dual 4ohm coils and will work happily @ 2ohm //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Great, I love this amp, but the sub I have at the moment is a MTX 4500 SVC and it just vibrates and sounds awful..//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks for the help.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
So how should I wire it, Will I blow the sub wired at 2ohm, Any help on this would save me and the sub //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
@ revrider1 LOL, lurve the sig.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
What's the peak power handling of the Infinity? 1400 watts? It should be able to handle 775 without blowing but is recommended for about 175 per coil. This would be so much easier if you were dealing with two subs!
Thanks, The problem is I dont have the room in the trunk, I use the trunk for work gear and I can only fit in a Stealhbox on the right side..
The sub arrived today, I will try and get it in there @ the weekend,
LOL... Lets see if I can fry da motha.. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
barfy
barfy
SF, CA
barfy
