mtx 251D amp powering 2 subs???
also, that setup is 4 ohms. that amp puts down a rated 80w @ 4ohms. which is //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
are they single 8 ohm subs?
well it comes with an 8g wire kit.Also it says its a mono amp but why does it have 2 sets of terminals for speaker?
with the wire kit its a decent deal,
many mono amps do ahve two speaker hook ups, that way its easier to hook up two subs with out having to jam wires into terminals. both go to the same output on the inside of the amp.
yea 100 for the wires, subs box and amp isnt too bad, it wont underpower the subs either you wont have to really worry about that. and alot of mono amps do have 2 sets of terminals just so it is more versatil{sp}
those were sold as packages and i would imagine the load for the two subs is two ohms.
wow i didnt even read the specs that well
i couldnt tell you if they were single 8 ohm subs or not it was dark out when i looked at them and in a rush i wasnt able to take the sub out and check and it was a girl so she had no clue
she had them in the back of her suzuki truck and they rattled a little bit
well teh crutch show the enclosure w/ subs in it. and it says 100-400w rms, 4 ohms
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
wow i didnt even read the specs that welli couldnt tell you if they were single 8 ohm subs or not it was dark out when i looked at them and in a rush i wasnt able to take the sub out and check and it was a girl so she had no clue
pics of girl?
massiveian
massiveian
massiveian
