Mt coils
bamaboy
War Eagle!!!
well the new MT is loud but until i get the new amp i want to change up wiring i measured the coils and they are getting 2.2-2.5 ish he said it was dual 1 or .7dcr now if its dual .7 then it would read 1.4 ish
my XXX was dual 2 and measures 1.4 or 1.5
is this one dual 1.4? so could i wireit in parallel?
would the a3000 handle it for daily?
(702)896-4823
That is the key to all the answers you seek. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I take it that you've wired the coils in series and the reading you have posted is on the pair of coils not just a single coil?
Anyway, try using a different DMM and see what it comes up with. Depending on the DMM used our coils come out between 1.8 and 2.3 Ohms per coil and ours are 2 Ohm coils. Remember that using a DMM will get you in the ballpark and it is also only measuring the driver at dead rest and you need to take into consideration the resistance of the DMM's leads if it has any.
Or you could just call David and RE and talk to him about it. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
866
Deff be a disaster and quite a shame blowing a freshly repaired amplifier in a few min.LOL. Id be very upset for sure. id recommend the wiring...
23
Lower the ohm the thicker the wire. The higher the ohm the thinner the wire but will have more windings. Lower ohm coils have a slight edge when...
bamaboy
War Eagle!!!
bamaboy
Auburn, Alabama
scottiej
    May 12, 2024
Brendon Jenness
    May 11, 2024
