MP3 CD vs. Regular Burned CD
If you take a 320 kbps mp3 and use it on a 24-bit Burr Brown head unit, will there be a noticable difference if you didnt have a good D/A converter?
Also, will the be a difference if you used a 260, 230, or 196 kbps mp3 on that same 24-bit Burr Brown head unit?
i wouldn't think the d/a converter would matter at all
It does. The conversion from digital to analog is, in a sense, a very "vulnerable" point for the signal. However, like all things, higher numbers don't mean much. There are good 1 bit D/A converters, and bad 24 bit ones.
It's one of the big reasons vinyl is held in such high regard, no D/A conversion to mess things up. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
if you copy a cd, how much quality do you lose?
Depends on wither or not you use compression, software used to make the copy, and program used to burn the new disc. It is possible to create an exact copy from the original disc.
for some reason i just figured you'd be bypassing it
Nope! Simply put, if you've got a record player, there's no D/A converter at all, because they're not needed and cost money to put there.
Vinyl = Analog -> Output
CD = Digital -> Analog -> Output
If you use a reciever with digital signal processing, it's a different story. They'll go from analog back to digital and then back to analog. It's why if you can go digital from the source to the reciever you get better quality with one of those.
Oh, Well I feel dumb then. =p
The answer is the same though. Any music stored digitally will have to go through a D/A converter before it can be played.
Done correctly, you can create an mp3 the is indistinguishable to the human ear.
On my system, to my ear, I would have to disagree with that. Mp3s just do NOT have the depth that a cd has. There is a reason it is called a "compressed" format.//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
X10,000,000
Maybe you don't have good mp3s?
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif Has nothing to do with it. I do have decent Mp3s which I ripped myself straight from CD to 320kbps. I can notice the difference. Especially on my home system which has NO road noise to contend with.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Ebonyisland
Ebonyisland
South Jersey
Ayrton
Mike Mccabe
