Moving stuff with sound
so? you cant even hear that high... lmao
did you even read the article? they are actually pouring a cup of coffee using sound pressure to move stuff. apparently it takes about 160+dB to create enough pressure to move stuff, but they are using super high frequencies of 24,000 Hz. how can you get such a high dB rating at such a high frequency? It's not about what you can hear, but actually creating 160dB+ with a speaker @ 24kHz that amazes me
yes, I did read it... sort of old news. you can do a lot with sound... weld, levitate, destroy. etc.
Dan Wiggins who used to own adire audio and invented XBL^2 tech used to design acoustic levatation devices for the military. I remember he said firing it at close range next to a concrete block and he could put burn marks on the concrete.. It's invariably a horn loaded design, probably a front loaded or tapped horn array with a very narrow bandwidth both in off axis response and frequency response.. Alot of energy over a very small area. Actual speaker type, maybe some sort of ribbon, not many speaker go to 24khz without inductance rolling it off. Probably all kinds of copper or even silver in the design, stupid expensive I'm sure haha.
kind of an offshoot. but if you think about moving things with sound, there has been theories about doing a similar act in reference to the pyramids. no amount of human force could move the 400 ton blocks of stone. how do you think they did it? im not saying it happened, but its definitely possible. the beauty of sounds is although we understand it, we dont utilize what its possibilities are.. as a tool for movement, a killer that travels through all surfaces, sound is pretty **** interesting..
clickclickw00t
clickclickw00t
United States
Dirtrider4eva
BP1Fanatic
BP1Fanatic
