schmittmj99
Hello
I recently upgraded my vehicle to a 2011 Nissan Frontier (from a 1995 Toyota Tacoma), and would like to move pieces, and possibly upgrade some parts from my old system to it.
My old system included:
Alpine CDA-9815 HU
Phoenix Gold XS4600
Phoenix Gold XS2500
Boston Acoustics Pro 6.5 2 way passive components
Boston Acoustics Pro 10.5LF subwoofer (x2)
I have already purchased or plan to reuse:
JVC KW-M730BT (no need for dvd/cd, but did want android auto, got a good deal used)
Phoenix Gold XS 4600 (75 WRMS x 4 @ 4 ohms, for active 2 way front)
Phoenix Gold XS 2500 (500 WRMS x 1 @ 4 ohms, for single subwoofer)
Sundown Audio SD-3 10 subwoofer (needed shallow mount for box under rear seat)
I know that much is in the install, but I do plan on keeping the vehicle "stock", so will be using the dash mounted tweeter location (firing at windshield), and the stock door panels. I will initially be leaving the rear stock speakers installed, but not hooked up (perhaps doing rear fill in the future).
Per Sonic Electronics I can take up to a 2.5" speaker (tweeter) on the dash, and 6" x 9" speakers in the front door panels.
I am torn on what to do with the fronts. I never really had an issue with the set of Boston Acoustics components, but am wondering if there is something better out there now for around that
I had read wonderful things about the pairing of SB Acoustics SB29RDCN-C000-4 and SB Acoustics SB17MFC35-4 run as an active set. Even though that is only a 6.5" woofer, it could be an option.
I am not much of a tweaker, but would like to have the system tuned some, so I am considering a used JBL MS-8 for its auto tune feature. I believe it also has the ability to manually tweak if I find I want to test those waters as well.
So my biggest questions would be ...
#1 : Am I on the right path with a JBL MS-8, or are there similar products I should be looking at instead (Rockford Fosgate DSR-1?, JL TWK?, MiniDSP C-DSP 6x8?). Most of those I had just seen mentioned, but am not fully aware of if they meet my requirement of auto tune with manual tweaking (again, should I decide to do some down the road).
#2 : Front speakers. A few options here ...
A: Find a decent 6" x 9" to pair with a tweeter in my price range to run active. (Again $250 or less greatly prefered)
B: Find a decent 6.5" set such as the SB Acoustics gear or some other suggested drivers to run active. (same $250ish budget max)
C: Stick with the Bostons, ditch the passive crossovers and run active.
D: Say "screw it" and use the $$$ from a DSP to get a nicer set of 6" x 9" coaxials (Hertz?, I do know there are more options for coaxials of that size then components).
Thank you for taking the time to read my post, and for any help/thoughts that you can offer.
Mike
Alpine CDA-9815 HU
Phoenix Gold XS4600
Phoenix Gold XS2500
Mike
