Mouting amp to my floor
i've always put a piece of wood under the carpet and just mounted the amp to that-if you do drill through the floor, make sure you don't hit anything "vital" such as gas tanks, etc
Then the wood would just move around..which defeats the purpose.
dont do amp straight to the floor..
i was stupid and drilled into my gas tank ... a few times before i noticed :eek:
i would do a thin layer of wood between the carpet and short screws... the carpet will hold it in place and the wood will hold it down...
should be quite stable.
dont do amp straight to the floor..i was stupid and drilled into my gas tank ... a few times before i noticed :eek:
look under car and find anything vital under it before drilling = ftw
can do what i did for my friends install pre drill a hole put a good right size bolt through and put a bolt through the bottom of the frame way take some more time but no one is gonna lift that amp there not gonna take that much time:p.
THXdts
THXdts
Maryland
audiobahnuser18
AJ (ACE)
    Jun 28, 2026
