orangetang
At last, a couple of days off work to do an install on my new F-150. After holding the tweeter in many different positions in the vehicle, it seems obvious that the two best places are on the dash, next to A-pillars pointing up, or in the sail panels facing backwards. The problem I've encountered is that the mount bezel is too wide for a rear facing mount in the sails, however they'll fit perfectly on the sides of the sails, at the cost of some sound stage. I can always turn up the tweeters a bit and mount them on the sides, but I'd like to ask first how I would be able to mount them in the desired location. Without the mounts, the tweeters will fit. It looks like I would need a 1 1/8" holesaw and some form of adhesive. I'm afraid that the adhesive will either not stick, or make a terrible mess. There is very little 'overhang' between the tweeter and it's grill. Maybe 1/8" at most. That doesn't leave a lot of surface area for great adhesion to the sail panel. What would you do? I've never seen tweets mounted where I want them, maybe there is a reason for that...? I'll post some pictures in a moment.
Desired Location
Gluable surface area...
Door Panel
Tweeter Grille - Only this rim is gluable to the sail
Inside Door
Tweets are of an Alpine SPR-17S component set.
Desired Location
Door Panel
Inside Door
