Mounting Brackets?
the set of speakers you want probably don't match the hole pattern of your application. so a mounting bracket is needed. you could create your own brack by using a mdf ring but you may run into clearance problems. also, the brackets allow ease of installion.
6.5" is the general size of the speaker. however, vehicles have certain screw patterns which aftermarket companies try to incorporate in their design. however, they can't incorporate all patterns. so, their are mounting brackets that solve the problem. i could be completely wrong about the bracket, just putting in my input.
i didnt get comps yet, burb is broken, need engine money
I will be making a MDF ring since the mids i want are deep and the factory location is deep in the door, i want to bring it out a bit.
That Guy 1
That Guy 1
somewhere in Uhh...
That Guy 1
