>>SQL<<
I know this subject has been discussed many times but I need to talk about it again.
I am redoing my system right now.
I went from 1 - 4 channel amp and 1 - 10" Sub to 2 amps and 2 - 12's in a huge box.
Box is 14" tall 33" wide and apx 24" deep.
This is in the trunk of a 97 Honda Accord.
Box is so big that it is going into the trunk through the rear seat.
Anyway I had planned on mounting the amps to the back of the seat, not going to work.
Both amps are large, really large. The only place I can put them is the top of the box.
Even then it is going to be hard cause I want the amps in the back under the rear deck and there will not be much room to work a screwdriver.
So what can I do? I have a roll of fat matt, can I make feet with a few layers of fatmatt and put that under the 4 corners of the amps?
I am putting about 1,400 watts to a pair of Skars in a Pro-Rabbit built box. The box is solid but with that much power it is going to vibrate.
What can I do?
Also I cannot build amp racks in the front corners of the trunk as I have a bit of water leakage there (just noticed it today, not coming from tailights) so I want the amps where it is dry and safe which will be under the rear deck.
thank you.
What can I do?
thank you.
