Ok so when I turn my car on the speaker makes a low rumble sound and if I shut my trunk or hit a bump it hits hard if beat and sometimes doesn't stop. I figured my rca's but ran new ones im running out of ideas
Could it possibly due to my second batt? Or could it be the remote cuz I had to run a wire from the fuse box. Ir could it be the amp cuz when I tap the top if the amp it does the hic up thing. Im trying to solve the issue before I get my new amp.
Unplug the rca's switch your DMM to continuity (should make a beep noise when you touch the two leads together). Take each RCA cable and touch the male connector with one DMM lead and the shield with another lead. If it produces a beep noise then the RCA is busted (the shielding broke and now the ground and the positive components of the RCA's are touching).
