More Mid-bass. Will it help??
don't do it they will run a different freq range so yea drowned out and what you do hear will be disappointing, if anything cut out 6.5 openings in the door panel and use the grill that comes with the kit should look good depending on what you get
Don't put mid basses in the trunk. Mid bass, despite it having the word "bass" in it, is directional. You want to keep it in your front doors if you can. Putting it behind you isn't worth the time simply because it will sound like everything is coming from your trunk (...which it will be lol). Fiberglass your door panel so it's all sealed up and drop a dedicated mid bass in there, or replace your current 6.5" with a strong midbass and add in a 4" mid higher up in the door to take care of the vocals (effectively running a 3 way)
What he said!
Make sure your doors are solid and get some good processing in there. Obviously some of the freqs will be coming from behind you...the point is to make them SEEM to come from in front of you. Proper phase alignment does exactly this.
IMO, virtually any decent 6.5 has enough midbass for 90% of installs, you just have to know how to get the most from your equipment....I'd work on that before you go grabbing more drivers..
Dont put them in the trunk for sure. Up front is best, but I have heard a few systems with midbass on the rear deck or rear panels that sounded really good. The times I heard them, they paid attention to the xover points and used some T/A. There was a guy locally that had 8's on his rear deck and 15's in his trunk. His car sounded incredible and you never felt like the midbass pulled from the rear. With anything, it is really all in the install.
How exactly would one go about sealing that portion up?
I used weather stripping foam and just wrapped it around the front of the speaker and used enough that it pushed against the door panel. I'm not completely sure this was the "right" way to do it, but it seemed to work fine for me.
Thats the only way i could figure, didnt know if there was a better route to it or not. I know also that I would need a lot of it haha.
schackel
schackel
San Francisco
keep_hope_alive
BP1Fanatic
BP1Fanatic
