Mono from head unit
say what?
you can get stereo bass by maybe going off the left and right channels. The sub channel is usually in mono , even if you see two sub preouts. it is still a mono.
You can get a fully active 4way xover and try to get stereo bass that way. blah blah.?
My amp is actually a stereo running in bridged mono mode. I never thought that the output from the JVC would be mono; I thought two RCA's = stereo. If mono, my problem solved. I can just use one output jack.
I doubt the HU outputs are mono. There would be an internal setting if that was possible. Should be stereo. With a bridged amp, you need both left and right inputs filled. The amp is creating a mono signal when bridged.
Why do you want to change it?
rjohn16
rjohn16
new york
rjohn16
