Mono/bridged 4 ch? Help please!
Neont4
CarAudio.com Newbie
Hello,
I have 2 x 300w RMS SVC 4ohm subs and I’m unsure what amplifier to go with, as I understand things I can either wire the subs in parallel to produce a 2ohm impedance to a 600w RMS mono block amp or I can wire each sub independently to a 4 channel amp that is rated for 2 x 300W RMS (bridged, 4ohm stable), correct?. What are the pro’s & con’s with each of these 2 options? Any and all input would be greatly appreciated. Cheers.
A mono block amp will more than likely be a Class D, which will be easier on you electrical, be easier to wire, have a smaller footprint, come with a bass knob, and easier to find one in that power range.
A four channel will probably be an Class A/B, which in my opinion, sounds better on subs than Class D amps.
Neont4
CarAudio.com Newbie
Neont4
New Zealand
1aespinoza
