Mono/bridged 4 ch? Help please!
  • 2
Neont4
Hello,
I have 2 x 300w RMS SVC 4ohm subs and I’m unsure what amplifier to go with, as I understand things I can either wire the subs in parallel to produce a 2ohm impedance to a 600w RMS mono block amp or I can wire each sub independently to a 4 channel amp that is rated for 2 x 300W RMS (bridged, 4ohm stable), correct?. What are the pro’s & con’s with each of these 2 options? Any and all input would be greatly appreciated. Cheers.
A mono block amp will more than likely be a Class D, which will be easier on you electrical, be easier to wire, have a smaller footprint, come with a bass knob, and easier to find one in that power range.
A four channel will probably be an Class A/B, which in my opinion, sounds better on subs than Class D amps.
I get it. I'd never run a tone through at full tilt to test just how much they can take before it goes all willie nelson either 🤣
72
4K
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
963
Buy the 4 ch and keep the other. Usually on a 5 ch there isnt much of a substage, but there are a couple with a 1k @1ohm ch., but very few. A 5...
Neont4
Neont4
New Zealand
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
