mono and 2 channel
Frijoles24
i owned a rf t3002 which was supposed to be a 2 channel amp
now i have a bxi 1606d which is mono //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
but they both had two set of speaker outputs....uh...like... + - + -
whats the difference?? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
and for mono is it left sub right sub?
The Bxi1606D is internally bridged. It makes it easier if ur running a pair of subs, cause than u dont have to wire the subwoofers togehter than hook it up to the amp. U can just use the 2 + and -'s and it'll bridge it for u. Thats why when u use it for 1 sub ur suppose to use the outter positive and the outer negative.
there's no bridging in a mono amp.
There are some dual mono's that are internally bridged, but those are rare.
A mono amp has a mono signal in and a mono signal out.
There's a lot more happening in a bridged amp.
If you're just running one speaker lead off a dual terminal mono amp it doesn't matter which (-) or which (+) you use, just pick one or the other.
Frijoles24
Frijoles24
Los Angeles, CA
n2audio
BP1Fanatic
BP1Fanatic
