well you should look at the manual, but i would assume that if it is a mono amp then there is only one channel. the extra speaker inputs just simplify the wiring. so either one should work.
with dvc 4's you can only wire to 2 or 8 ohms i believe for each sub, and then wire both to the amp and the amp will see a total of a 1ohm load. so yes.
