mono amp is not bridgeable have a question
Is your amp 1 ohm stable? If not you will have to wire the coils of the sub in series. If it is, you can either wire the coils in parallel in the box and use a single terminal or have a second terminal installed and use both sets of terminals on the amp. Either way will get the same result.
blowthemup
blowthemup
North Carolina
blowthemup
