Exactly.ok mr. 19 posts wtf did you have in mind
ya same here, he does a great job.And TheMommyVan is the **** at making boxes.
He did mine up right and I am extremely happy with it.
nvmand i bet you know what that sounds like.//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
So a high number means it is going to sound good? You are a tool. If he wanted high numbers it would be tuned in the 50hz range. Its tuned to 33hz.yupp. i bet that system sounds like it with the port firing forward and the subs pretty much sealed off in the back.... ive never had luck with weird placements. get it metered and we will know.
nvmSo a high number means it is going to sound good? You are a tool. If he wanted high numbers it would be tuned in the 50hz range. Its tuned to 33hz.
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gifwell ur the tard. considering u can do good number tuned low. mine was tuned to 34 with much less equipment and i bet it meters higher.
true. but it is ca.comwhat the hell happend to this thread?? acting like a bunch of 2yr olds
