Mojo vs D2 - Results inside!!!!
JeremyD
OK. I know alot of people lately have been asking for head to head comparisons between these two amps. Well, today I did a direct comparison between the two. The earthquake was an 02 model, stock. While the mojo was a brand new modded one (modded to take high voltage). The install used was my personal box consisting of 2 SEXXX 10's wire to 1/2 ohm. Both amps were cranked all the way to clipping, then backed off just a hair. The electrical system was 12v holding a steady charge of about 13.4, and 11.5-12.5 during burps. The first run was done with the d2 and resulted in 146.5 db. The amp was then swapped for the mojo. The batteries were recharged to ensure fair testing. On run 2, the mojo did a 146.9. So that being said, the mojo was about .4 db louder than the d2 at 1/2 ohm on a 12v system.
I would just like to send special thanks out to jesse seigars and the boys from team 420 for the amp and all their help //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
very nicely done. now lets check to see which one fries an egg first:D. my $$ goes out to the D2 on tis one.
adam
adam
After 5 minutes of sweeps and bass tracks with my d2 at .5 ohm, it was hot enough to fyr an egg. A little bit of AC in my buddies car took care of that though //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
wang...
did you let the coils cool down on the sub before you burped again?
oh and on your box you got tons of blade pinch..
:p
Cool??? I had limited time, but they don't get that warm off a couple burps though.
Cut those pieces myself //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I am no carpenter and my table saw sucks. I need a new one...
JeremyD
JeremyD
New Bedford, MA
mattj
