mojo quad 1 ohm help!!!!
its_ray_ray
FTW Michael Jackson Mario
ok i just got a memphis quad 1 ohm 15" beat your block down sub, so i need to know how to wire it... my fusion will do 1 ohm nicely so will i need to run a strand of wire from each voice coil to my amp for a 1 ohm load? or is there a prettier way to do it? lol
but could i also just run the 4 strands wire, like i mentioned earlier?
If you mean connecting All four negatives together and all 4 positives together. then no you cant do that. You will parallel all four coils and it will be way lower then what your amp can do.
Look at the specs on your sub for the hole size. You have to wire the sub correctly to get your 1ohm load just as others have already stated. I am sure if you do a search online or even look up the spec sheet for your sub it will tell you how to get your 1ohm load.
its_ray_ray
its_ray_ray
Athens, Tn
got-one-eight
