mmats amp
hoorider
i have an mmats d100hc class-d amp
ok i dont know what this amp can do or whats it worth but i know i would like to have four 12's but i dont know 12's to go with i was lookin at the cerwin vega v-max subs i would like to hit around 153db but i dont know but i only lookin to spend about 225 on each sub and could someone me tell all the things i might need to hit 153db so could someone help me please
i have an mmats d100hc class-d amp ok i dont know what this amp can do or whats it worth but i know i would like to have four 12's but i dont know 12's to go with i was lookin at the cerwin vega v-max subs i would like to hit around 153db but i dont know but i only lookin to spend about 225 on each sub and could someone me tell all the things i might need to hit 153db so could someone help me please
you'll need more than that amp it does 1400watts @ .67ohm 14.4v
4 12s and only 225 per sub? 150 is loud for a daily driver. You could probably do it with type Rs if it was done correctly. Or ssds. But you need alot more power.
150 on a termlab is no easy task. The amp you have was made to run (6) 4ohm subs and as stated before does full power at .67ohms. You will need more power to achieve that score. Why 150 or 153? if it is about the hitting a 150 then forget about it sounding good while doing it. I would advise using a sealed enclosure with 3 decent DVC subs and forget about the 150. Build your system to play loud and sound good while doing it. And if your looking to impress people go with a low tuned enclosure around 30 hz and a couple thousand watts. You will be alot happier in the end.
BTW if you want to get rid of that amp let me know, I collect all the older MMats amps.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
what are some subs i could get to sound
i really dont know what subs or how many subs or size to get shit i have some many subs in mine but i just dont know
could someone please help me out
hoorider
hoorider
louisville,ky
hoorider
